The message indicates the failure in adding a Customer VLAN to the floodin group of the VLAN or the I-SID. Lower the severity to narrow the cause of failures. The cause could be in the PSI library or the low on memory in the system.
Retry the configuration so that the ports are re-added or re-deleted to/from the flooding group of I-SID or VLAN.
Debug-Summary
Failed to remove CNP ports from VLAN %vlanName% for I-SID %isidName% when %info%.
| Name | Type |
| vlanName | String |
| isidName | String |
| info | String |
